Discuss
whirlpool dishwasher not draining
 in
Dishwasher Repair
Put dishwasher in January, 2013 in kitchen island. Drain hose goes under floor to sink air lock and garbage disposer
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » whirlpool dishwasher not draining
  #1 (permalink)
Old 05-28-2013, 02:28 PM
Junior Member
mdauer2002 is on a distinguished road
Default whirlpool dishwasher not draining
Model Number: whirlpool wdf750say   Brand: Whirlpool   Age: Less than 1 year
Put dishwasher in January, 2013 in kitchen island. Drain hose goes under floor to sink air lock and garbage disposer (and yes I knocked the hole out of the disposer). Total length of hose pipe is 12 feet which this model said it could pump. Has worked great until this last weekend. Now it is not draining all the way. Checked the screen and basket - was kind of clogged with snotty gunk. Thought that was the issue so cleaned that, put it back in and hit "drain" button. Motor runs, kind of clicks (maybe always sounded like that, never really listened that closely) and small amount of water comes through air lock on sink (again never looked before, but seems to be less than I would have expected). Got underneath and disconnected drain tube from pump. Water freely exits pump once disconnected and I am able to blow air through waste pipe to sink (although seemed harder than expected). Ran a half gallon of vinegar through drain. After a run there is still 3 inches of water at bottom of tub. I can hit drain button and small qty does pump out through air lock, but takes two or three times of hitting the button for tub to drain out completely. Does it seem more likely that it is a hose issue or a pump issue? Could the pump have burned out because the strainer basket was so clogged? Previous posts talk about a check valve, I couldn't find on in the drawing for this model. Any other way to check whether the pump is working without disconnecting it completely?
Related Models
Whirlpool WHP1000SB1 PEDESTAL
Whirlpool WHP1000SK0 PEDESTAL
Whirlpool WHP1000SK1 PEDESTAL
Whirlpool WHP1000SL0 PEDESTAL
Whirlpool WHP1000SL1 PEDESTAL
Whirlpool WHP1000SQ0 PEDESTAL
Whirlpool WHP1000SQ1 PEDESTAL
Whirlpool WHP1000ST0 PEDESTAL
Whirlpool WHP1000ST1 PEDESTAL
Whirlpool WHP1000SU1 PEDESTAL
Whirlpool WHP1500SA0 PEDESTAL
Maytag WHP1500SA1 PEDESTAL
Whirlpool WHP1500SB0 PEDESTAL
Maytag WHP1500SB1 PEDESTAL
Whirlpool WHP1500SC0 PEDESTAL
Maytag WHP1500SC1 PEDESTAL
Whirlpool WHP1500SL0 PEDESTAL
Maytag WHP1500SL1 PEDESTAL
Whirlpool WHP1500SQ0 PEDESTAL
Maytag WHP1500SQ1 PEDESTAL
Whirlpool WHP1500ST0 PEDESTAL
Maytag WHP1500ST1 PEDESTAL
Whirlpool WHP1500SU0 PEDESTAL
Maytag WHP1500SU1 PEDESTAL
Whirlpool WHP32812 30" Electric Range Self Clean Oven
Whirlpool WHP54802 30" Electric Range Self Clean Oven
Whirlpool WHP54803 30" Electric Range Self Clean Oven
Whirlpool WHP83812 30" ELECTRIC RANGE CERAN COOKTOP SELF CLEAN
General Electric WHRE5260E0CC Washer
General Electric WHRE5260E0WW Washer
General Electric WHRE5260E1CC Washer
General Electric WHRE5260E1WW Washer
General Electric WHRE5260E6CC Washer
General Electric WHRE5260E6WW Washer
General Electric WHRE5550H0WW WASHER
General Electric WHRE5550H1WW WASHER
General Electric WHRE5550H2WW WASHER
General Electric WHRE5550K0WW WASHER
General Electric WHRE5550K1WW WASHER
General Electric WHRE5550K2WW WASHER
General Electric WHRE5550K3WW WASHER
General Electric WHSB8000B0CC Washer
General Electric WHSB8000B0WW Washer
General Electric WHSB8000B1CC Washer
General Electric WHSB8000B1WW Washer
General Electric WHSB9000B0CC Washer
General Electric WHSB9000B0WC Washer
General Electric WHSB9000B0WW Washer
General Electric WHSE3100A0WB Washer
General Electric WHSE3100A2WB Washer
General Electric WHSE5240D0CC Washer
General Electric WHSE5240D0WW Washer
General Electric WHSE5240D1CC Washer
General Electric WHSE5240D1WW Washer
General Electric WHSE5240DCCC Washer
General Electric WHSE5240DCWW Washer
General Electric WHSR2070V2WB Washer
General Electric WHSR2070V3WB Washer
General Electric WICB103CV1WC Washer
Frigidaire WIDH3 Frg(v18) / Top Loading Washer
Frigidaire WIDH4 Frg(v3) / Top Load Washer
Frigidaire WIDL3 Frg(v19) / Top Loading Washer
Frigidaire WIDL4 Frg(v2) / Top Load Washer
Frigidaire WIDW3 Frg(v20) / Top Loading Washer
Frigidaire WIDW4 Frg(v1) / Top Load Washer
Frigidaire WILH1 Frg(v2) / 27 " Washer
Frigidaire WILL0 Frg(v2) / 27 " Washer
Frigidaire WILL1 Frg(v3) / 27 " Washer
Frigidaire WILW0 Frg(v1) / 27 " Washer
Frigidaire WILW1 Frg(v1) / 27 " Washer
Frigidaire WIMA1 Frg(v16) / Washer
Frigidaire WIMA2 Frg(v17) / Washer
Frigidaire WIMA3 Frg(v15) / Washer
Frigidaire WIMF1 Frg(v18) / Washer
Frigidaire WIMF2 Frg(v19) / Washer
Frigidaire WIMF3 Frg(v16) / Washer
Frigidaire WIMH1 Frg(v20) / Washer
Frigidaire WIMH2 Frg(v21) / Washer
Frigidaire WIMH3 Frg(v17) / Washer
Frigidaire WIML1 Frg(v22) / Washer
Frigidaire WIML2 Frg(v23) / Washer
Frigidaire WIML3 Frg(v18) / Washer
Frigidaire WIMW1 Frg(v24) / Washer
Frigidaire WIMW2 Frg(v25) / Washer
Frigidaire WIMW3 Frg(v19) / Washer
Frigidaire WISCL2 Frg(v3) / Washer
Frigidaire WISCL3 Frg(v3) / Washer
Frigidaire WISCL5 Frg(v3) / Top Loading Washer
Frigidaire WISCL6 Frg(v4) / Top Load Washer
Frigidaire WISCLL0 Frg(v4) / 27 " Washer
Frigidaire WISCLL1 Frg(v6) / 27 " Washer
Frigidaire WISCLL2 Frg(v2) / 27 " Washer
Frigidaire WISCLW0 Frg(v3) / 27 " Washer
Frigidaire WISCLW1 Frg(v4) / 27 " Washer
Frigidaire WISCLW2 Frg(v1) / 27 " Washer
Frigidaire WISCW2 Frg(v4) / Washer
Frigidaire WISCW3 Frg(v4) / Washer
Frigidaire WISCW5 Frg(v4) / Top Loading Washer
Frigidaire WISCW6 Frg(v3) / Top Load Washer
Frigidaire WISDL2 Frg(v21) / Top Loading Washer
Frigidaire WISDL3 Frg(v5) / Top Load Washer
Frigidaire WISDLL0 Frg(v6) / 27 " Washer
Frigidaire WISDLL1 Frg(v9) / 27 " Washer
Frigidaire WISDLW0 Frg(v5) / 27 " Washer
Frigidaire WISDLW1 Frg(v7) / 27 " Washer
Frigidaire WISDW2 Frg(v22) / Top Loading Washer
Frigidaire WISDW3 Frg(v4) / Top Load Washer
General Electric WISQ416AT5WW Washer
General Electric WISQ416AT6WW Washer
General Electric WISQ416AT7WW Washer
General Electric WISQ416AT8WW Washer
General Electric WISQ416ATAWW Washer
General Electric WISQ416BT5WW Washer
General Electric WISQ416BT6WW Washer
General Electric WISQ416BT7WW Washer
General Electric WISQ416BT8WW Washer
General Electric WISQ416BTAWW Washer
General Electric WISQ416CT5WW Washer
General Electric WISQ416CT6WW Washer
General Electric WISQ416CT7WW Washer
  #2 (permalink)
Old 05-30-2013, 03:04 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
This is a difficult one.
I personally would not run a drain line 12 feet and have never done this so all I can do is give a few suggestions.
"snotty gunk" dose not bode well as it sounds like something is growing in your unit and if it is there it will also be in the drain tube.
If you are using liquid or the pucks I would switch to powdered detergent.
If the drain line you are using is the type that has the ridges I would replace at least the portion under the floor with non ridged hose or pipe. The ridges will slow down water flow and also grab stuff.
Does your place have a basement?
If it does then I would try to tap into a drain line in the basement.
You just have to be sure that there is a trap between the sewer line and the dishwasher drain. you could form the trap out of the flex drain line. Also that the drain can handle the flow.
For instance if you are above your utility room you could drain into the stand pipe of the washing machine. After it's trap add a T and the two stand pipes one for the washer and another for the dishwasher.
You will probably have to pull the drain pump just to be sure that it also does not have gunk in it.
__________________
  #3 (permalink)
Old 05-30-2013, 01:01 PM
Junior Member
Default
So I checked all the lines, from the pump to the air lock - no clogs, no buildup, drained them and able to blow through perfectly easily.
I will consider moving it to drain down to basement (washer/dryer right there and probably won't even need new hoses, just could go right into the washer p-trap). Maybe that will pervent this from happening again in future.
Still doesn't seem to address the slow drain though. Could it be the sensor? It reliably shuts off with the basin full of water. I can push drain, and it drains for a good minute or so, but the water is still up to the top of the basket. A second push of "drain" gets it all the way down. It seems so weird that the pump would work, but only at about 50% capacity.
Maybe I just need to get the pump out of there and clean the impeller? How do I get the drain pump off to see in there? Can I do it without taking the d/w out of the cabinet?
  #4 (permalink)
Old 05-30-2013, 01:03 PM
Junior Member
Default
  #5 (permalink)
Old 05-30-2013, 02:17 PM
Senior Expert
APP Volunteer
Default
Below is the pump
Part number: AP4320199
Click on the picture for more views /info.
Looks like it has a clip and then twists off.
I am not sure if you will be able to reach it with the unit in place.
Often it depends on how good you are working blind as you probably will not be able to see much once you get your arm in there. Also how tolerant you are to scrapes and scratches at least I usually end up with a couple.
Below is a video that should help.
Drain Pump Replacement (part #661658) - Whirlpool Dishwasher Repair - YouTube
If you decide to re-route your drain I would loop it up some before going through the floor.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Dishwasher not draining entirely johnwartjr Dishwasher Repair 6 01-30-2013 09:59 AM
Whirlpool dishwasher not draining cfotopoulos Dishwasher Repair 0 09-18-2012 05:49 AM
Whirlpool Dishwasher not draining miketran Dishwasher Repair 3 01-28-2011 10:58 AM
whirlpool dishwasher not draining Tubhot2 Dishwasher Repair 6 01-24-2011 04:05 PM
Whirlpool Dishwasher Not Draining pgonza02 Dishwasher Repair 0 04-26-2010 02:29 PM
