| » Control Panel |
Model Number: KUDS25SHWH1 Brand: Kitchen Aid Age: 5 - 10 years
Child Safe mode will not release. Replace control panel? Or is there somthing I am over looking?
Parts for Whirlpool KUDS25SHWH1 Dishwasher - AppliancePartsPros.com See the attachment for the tech sheet. Unforetunately it does not give a pin-out for the keypad. The problem will be either with the keypad or the control board. If the lock light is flashing I would try the keypad first as this could be a stuck key problem. If it is on solid I would replace the control board. Either one is a bit of a gamble.
__________________
Give the parts people a call they have more info than I do.
There are a number of versions of the control panel listed but they are all just black. They should be for the different colors so it may just be a problem with this data set.. Always a possibility that the other colors are no longer available, only the parts specialists will know. Unsticking a key is very iffy. Thy are usually bubble type keys. There is a possibility that if you remove the panel and put it in a freezer overnight that the thermal contraction caused by freezing it will pop it back up. I used to use a product called FreezeIt re: a freezing spray, to just freeze the one key area. This may mess up the plastic protective cover. Works maybe 1 in 10 times.
__________________
| Display Modes | |
| Oven control panel says "locked door" and does not work. Need new control panel. | ferhan | Oven Repair (including Ranges and Cooktops) | 3 | 08-15-2011 06:45 PM |
| Need help removing control panel and front panel to get at the drain pump | jthenne | Washer Repair | 2 | 02-16-2011 02:15 PM |
| Control Panel or Electronic Control - which causes blinking panel lights? | MarcLCH | Dishwasher Repair | 1 | 02-25-2010 03:25 AM |
| tranformer blew on control panel need specs for new transformer not control panel | kaydog2009 | Oven Repair (including Ranges and Cooktops) | 0 | 05-11-2009 07:22 AM |
| Replace control panel or just control panel housing? | Max Strano | Dishwasher Repair | 1 | 08-26-2008 06:02 PM |
