Discuss
Bosch Dishwasher won't cycle
 in
Dishwasher Repair
Machine will fill and start washing but will not cycle. For instance the timer will just stay washing on 46
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch Dishwasher won't cycle
  #1 (permalink)
Old 08-08-2007, 12:22 PM
dspecht dspecht is offline
Junior Member
dspecht is on a distinguished road
Default Bosch Dishwasher won't cycle
Model Number: SHU5305 UC/06   Brand: Bosch   Age: 5 - 10 years
Machine will fill and start washing but will not cycle. For instance the timer will just stay washing on 46 min. for hours.
Related Models
Bosch SHU5305 UC/06 (FD 7705-7912)
Bosch SHU5305 UC/11 (FD 8001-8003)
Bosch SHU5305 UC/12 (FD 8003-)
Bosch SHU5306 UC/06 (FD 7705-7912)
Bosch SHU5306 UC/11 (FD 8001-8003)
Bosch SHU5306 UC/12 (FD 8003-)
Bosch SHU5307 UC/12 (FD 8003-)
Bosch SHU5312 UC/06
Bosch SHU5312 UC/11
Bosch SHU5312 UC/12
Bosch SHU5314 UC/06
Bosch SHU5314 UC/11
Bosch SHU5314 UC/12
Bosch SHU5315 UC/06
Bosch SHU5315 UC/06 (FD 7705-7912)
Bosch SHU5315 UC/11
Bosch SHU5315 UC/11 (FD 8001-8003)
Bosch SHU5315 UC/12
Bosch SHU5315 UC/12 (FD 8003-)
Bosch SHU5316 UC/06
Bosch SHU5316 UC/11
Bosch SHU5316 UC/12
Bosch SHU5317 UC/12
Bosch SHU53A02 UC/14 (FD 8211-)
Bosch SHU53A05 UC/14 (FD 8211-)
Bosch SHU53A06 UC/14 (FD 8211-)
Bosch SHU53E02 UC/14 (FD 8211-)
Bosch SHU53E05 UC/14 (FD 8211-)
Bosch SHU53E06 UC/14 (FD 8211-)
Whirlpool SHU55000
Whirlpool SHU55010
Whirlpool SHU55040
Whirlpool SHU55041
Whirlpool SHU55042
Whirlpool SHU60010
Whirlpool SHU60011
Whirlpool SHU60020
Bosch SHU66C02 UC/14 (FD 8211-)
Bosch SHU66C05 UC/14 (FD 8211-)
Bosch SHU66C06 UC/14 (FD 8211-)
Bosch SHU66C07 UC/14 (FD 8211-)
Bosch SHU66E02 UC/14 (FD 8211-)
Bosch SHU66E05 UC/14 (FD 8211-)
Bosch SHU66E06 UC/14 (FD 8211-)
Bosch SHU66E07 UC/14 (FD 8211-)
Bosch SHU6802 UC/06 (FD 7705-7912)
Bosch SHU6802 UC/11 (FD 8001-8003)
Bosch SHU6802 UC/12 (FD 8003-)
Bosch SHU6805 UC/06 (FD 7705-7912)
Bosch SHU6805 UC/11 (FD 8001-8003)
Bosch SHU6805 UC/12 (FD 8003-)
Bosch SHU6806 UC/06 (FD 7705-7912)
Bosch SHU6806 UC/11 (FD 8001-8003)
Bosch SHU6806 UC/12 (FD 8003-)
Whirlpool SHU70000
Whirlpool SHU70001
Whirlpool SHU70010
Whirlpool SHU70040
Whirlpool SHU70041
Whirlpool SHU70050
Whirlpool SHU70051
Whirlpool SHU70052
Whirlpool SHU75000
Whirlpool SHU75010
Whirlpool SHU75040
Whirlpool SHU75042
Whirlpool SHU80000
Whirlpool SHU80001
Whirlpool SHU80010
Whirlpool SHU80040
Whirlpool SHU80041
Whirlpool SHU80042
Bosch SHU8802 UC/12 (FD 8105-)
Bosch SHU8805 UC/12 (FD 8105-)
Bosch SHU8806 UC/12 (FD 8105-)
Bosch SHU8812 UC/12 (FD 8105-)
Bosch SHU8815 UC/12 (FD 8105-)
Bosch SHU8816 UC/12 (FD 8105-)
Whirlpool SHU90000
Whirlpool SHU90001
Whirlpool SHU90002
Whirlpool SHU90010
Whirlpool SHU90040
Whirlpool SHU90041
Whirlpool SHU90050
Whirlpool SHU99000
Whirlpool SHU99001
Bosch SHU9902 UC/06
Bosch SHU9902 UC/06 (FD 7905-7912)
Whirlpool SHU99040
Whirlpool SHU99041
Bosch SHU9905 UC/06
Bosch SHU9905 UC/06 (FD 7905-7912)
Whirlpool SHU99050
Whirlpool SHU99052
Whirlpool SHU99053
Bosch SHU9906 UC/06
Bosch SHU9906 UC/06 (FD 7905-7912)
Bosch SHU9912 UC/06
Bosch SHU9912 UC/06 (FD 7908-8002)
Bosch SHU9912 UC/11
Bosch SHU9912 UC/11 (FD 8002-8003)
Bosch SHU9912 UC/12
Bosch SHU9912 UC/12 (FD 8003-)
Bosch SHU9915 UC/06
Bosch SHU9915 UC/06 (FD 7908-8002)
Bosch SHU9915 UC/11
Bosch SHU9915 UC/11 (FD 8002-8003)
Bosch SHU9915 UC/12
Bosch SHU9915 UC/12 (FD 8003-)
Bosch SHU9916 UC/06
Bosch SHU9916 UC/06 (FD 7908-8002)
Bosch SHU9916 UC/11
Bosch SHU9916 UC/11 (FD 8002-8003)
Bosch SHU9916 UC/12
Bosch SHU9916 UC/12 (FD 8003-)
Bosch SHU9922 UC/12 (FD 8003-)
Bosch SHU9925 UC/12 (FD 8003-)
Bosch SHU9926 UC/12 (FD 8003-)
Bosch SHU9952 UC/12 (FD 8105 -)
  #2 (permalink)
Old 08-14-2007, 02:23 PM
Malise Malise is offline
Junior Member
Malise is on a distinguished road
Thumbs down Bosch SHU4306UC/U06. My dishwasher also did not complete the cycle
I have the Bosch SHit, shame on U 4306UC/U06. My dishwasher also did not complete the cycle.
I bought this dishwasher new and installed it myself in Nov. 2000; of coarse the warrantee on the electronics was only good for 5 years.
I changed my old dishwasher (Whirlpool) because of the age, noise and the cosmetic rust. What’s interesting is my old unit was over 20 years and I never had to call a service man out.
After having the repair man out and spending $100 for labor and $200 for a new Control Panel, it’s now running again. What I should have done is re-solder the heater relay myself and see if this worked. Before I put out the expense of a repair, which was 50% of the original cost. If you’re willing to take out 6 screws to remove the top cover, you will see that your circuit board will have a burnt solder joint, Easley repairable with a $15.00 solder iron!
Bosch should have a recall on these Control Panel and have there service technicians change it out at there expense, instead of taking advantage of the Consumer for there own Corporate Profits.
I only wish Consumers Reports would talk with me before they publish another report.
Malise
  #3 (permalink)
Old 08-15-2007, 12:46 AM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Default
dspecht
Most likely the problem with your dishwasher is a bad control board. You can try to follow the advise from Malise and check the control board for burned solder joint but based on my experience this is very seldom situation. If you decide to try it first, I would recommend to mark all wires carefully before remove them. There is no wiring diagrams and you can end up with very complicated puzzle.
- The part number for the new control board is AP2802870
- Here are break down diagrams for the Bosch dishwasher Model SHU5305 UC/06 (FD 7705-7912)
Good luck.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing Drain Hose on Bosch Dishwasher Lorenzo Dishwasher Repair 3 10-02-2008 12:31 PM
NEW bosch dishwasher will not start code 119 rjake48 Dishwasher Repair 1 10-05-2007 04:45 AM
Bosch Dishwasher JohnM Dishwasher Repair 6 09-04-2007 09:06 AM
Bosch dishwasher Elise Dishwasher Repair 2 08-13-2007 07:19 PM
Dishwasher cycle never changes prturner Dishwasher Repair 1 08-02-2007 05:44 PM
