lacken
#1 Posted : Friday, March 4, 2011 5:22:06 PM(UTC)
lacken
had a problem where no water would go in. Read a lot about water valve and float. Float assembly moved well, no sticking...there was water in the bottom pan. vacuumed the water out and started the dw. Flood. Emptied water from bottom pan again and restarted. no water. Noticed that I could see the float rod looking through the toe kick, and it was all the way up. reached in and pushed it down..water ran in. So something is leaking water into the bottom pan setting off the float switch. I thought maybe the hose off the back of the fill valve leaking, but mentioned to someone who does appliance repair and they said "leaking drain pump". Does this sound plausable? I'd appreciate any help/advise offered. Thanks
lacken
#2 Posted : Wednesday, March 16, 2011 8:22:29 PM(UTC)
lacken
Ok an update. After watching the dishwasher for the complete wash cycle I found out this: during the fill the water intlet system fills and sprays water out of the vent hole. If the washer was installed and had the side panel in place the water would fill the bottom pan and activate the float switch stopping the water entering. So the problem is between the water inlet and the pressure chamber. The water coming in is more then will go into the pressure chamber. So there might be a restriction there or too much pressure from the inlet valve. Is this valve more then an "on/off" valve? I don't know if this is the same layout as the SHV modes.
lacken
#3 Posted : Wednesday, March 23, 2011 5:44:53 PM(UTC)
lacken
I feel that the problem is down to the water inlet valve, the control module or the level switch in the pressure chamber. The problem didn't creep up, it just was one time it worked, the next it didn't. Does the wood panel need to come of in the process of finding the control panel? If so, how?
new post:http://forum.appliancepartspros...ut-water.html#post386409
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Lg ice maker leaking (Refrigerator & Freezer Repair)
by Guest 4/10/2024 2:58:55 PM(UTC)
Ice Buildup Under Freezer Platform, Leaks into Fridge (Refrigerator & Freezer Repair)
by MochaFiend 4/2/2024 3:21:56 PM(UTC)
KitchenAid KSSP42QTS00 Ice dispenser leaking (Refrigerator & Freezer Repair)
by sternern 3/20/2024 2:21:47 PM(UTC)
HELP!!! Maytag Lat9604abe leaking from weeping holes in tub seal (Washer Repair)
by gocanada72 3/18/2024 5:53:29 AM(UTC)
Refigrator. leaks (Refrigerator & Freezer Repair)
by celshaug 3/2/2024 8:57:46 AM(UTC)
rubber hose conector decayed and leaking. (Dishwasher Repair)
by Guest 2/25/2024 3:33:37 PM(UTC)
Frigidaire Affinity Washing Machine - Leaking only sometimes (Washer Repair)
by omf_24 2/24/2024 4:45:41 PM(UTC)
Water reservoir is leaking and freezing (Refrigerator & Freezer Repair)
by Guest 2/24/2024 12:38:19 PM(UTC)
Bottom Freezer Leaking Water (Refrigerator & Freezer Repair)
by fscel 2/13/2024 11:22:53 AM(UTC)
Older Kenmore Washer leak (Washer Repair)
by Guest 2/1/2024 9:56:27 AM(UTC)
GE GSD2200Z01AD Leaking out front bottom (Dishwasher Repair)
by jappel 1/22/2024 7:02:46 AM(UTC)
Whirlpool Water Inlet Valve Repair for Leak (Refrigerator & Freezer Repair)
by ForumUser1 12/23/2023 12:57:44 PM(UTC)
Dishwasher- severe leak (Dishwasher Repair)
by crossdw 12/7/2023 10:41:12 AM(UTC)
GSD5120D00BB GE dishwasher leaking at the bottom corners (Dishwasher Repair)
by ron Minervino 12/7/2023 9:15:11 AM(UTC)
