LS1M
#1 Posted : Tuesday, February 22, 2011 7:01:33 AM(UTC)
LS1M
This dishwasher washed dishes great when it was new, but has gradually gone downhill. I've tried different soaps (Cascade Complete with Bleach worked for a while, then we tried the pellets with the blue center, then electrosol powder with jetdry agent), different settings (now it won't clean even on pots & pans setting with hi-temp wash & sani rinse). I've taken the spray arms off to check for clogs, taken the drain assembly out, run the hot water at the sink before starting a load, moved all dishes away from the soap door, even stopped the cycle when the soap door opens to pour boiling water in, to make sure the soap gets dissolved. It drains, it gets the water hot (120 or 140 degrees, can't really remember), but I think it won't spray as hard as it used to. There's a filter underneath that I cleaned out, but it's an inlet filter and it's filling up/draining just fine. I've even washed the dishes, put just a few in the dishwasher (covered with soap suds), then when I run it through a cycle (even "quick rinse") there's still soap on the dishes. Once my wife noticed a small hair on top of a glass; seems like the water should have knocked that off.
Does the pump wear out over time? It's still a pretty new dishwasher; I hate to just get a new one every 2 years. Or is this typical of Kenmore, and if so, what's a good replacement?
-Mark
Jeff / APP Team
#2 Posted : Tuesday, February 22, 2011 11:49:05 AM(UTC)
Jeff / APP Team
You need to take the motor assembly apart and inspect the impeller assembly. Make sure it's not broke or wore down. Also look and make sure the opening for it in your sump assembly is not clogged. Here is the part number for the impeller Kit. Hope this helps. Part number: AP3738238
Maytag dishwasher not cleaning top shelf very well. (Dishwasher Repair)
by Guest 10/20/2022 10:23:08 AM(UTC)
LG Dishwasher not cleaning dishes (Dishwasher Repair)
by diyrepairdishwasher 9/30/2022 5:50:39 AM(UTC)
Whirlpool WDT750SAHZ0 - Dishwasher not cleaning dishes (Dishwasher Repair)
by djschumacher 3/7/2022 12:45:43 PM(UTC)
GE dishwasher not cleaning- pump okay, but not fully spraying (Dishwasher Repair)
by Guest 9/28/2021 12:47:19 PM(UTC)
Older Hotpoint Dishwasher not Cleaning (Dishwasher Repair)
by Polly147 8/23/2015 3:04:31 PM(UTC)
Frigidaire dishwasher not cleaning (Dishwasher Repair)
by mattmassey84 8/6/2014 10:21:17 PM(UTC)
Kitchenaid dishwasher not cleaning top rack (Dishwasher Repair)
by mcl143 5/5/2013 11:36:42 AM(UTC)
GE Profile dishwasher not cleaning well (Dishwasher Repair)
by edjr 3/30/2013 4:25:14 AM(UTC)
Dishwasher not cleaning properly (Dishwasher Repair)
by BANDIT030502 2/12/2013 6:47:58 PM(UTC)
LG Dishwasher not cleaning well (Dishwasher Repair)
by gr8filed 2/6/2013 2:34:30 AM(UTC)
by lizard2000 1/2/2012 5:47:43 AM(UTC)
GE dishwasher NOT CLEANING DISHES (Dishwasher Repair)
by RAY PINOLA 11/28/2011 2:21:05 PM(UTC)
Dishwasher not cleaning dishes well all of a sudden (Dishwasher Repair)
by vballplayer30 10/18/2011 4:48:48 PM(UTC)
Whirlpool dishwasher not cleaning top dishes (Dishwasher Repair)
by 35cents 1/16/2011 11:44:46 AM(UTC)
kitchenaid dishwasher not cleaning (Dishwasher Repair)
by dschag 1/7/2011 10:36:49 AM(UTC)
