WP Side by Side fridge door unlevel and gasket needs changing
Hi, I’m having difficulty finding instructions on leveling my fridge door and changing the seal. The door does not close properly and if we open/close the freezer, the fridge will usually pop open as well. The gasket has several gaps and needs to be removed, but appears to be in between the door and the outer shelving and I’m afraid I’ll break the door by pulling on the gasket but I don’t see any screws. Please advice prior to my ordering parts so I’ll be confident to fix it. Thanks in advance!
Parts for Whirlpool ED5VHEXVB00 Refrigerator - AppliancePartsPros.com
For the door closing problem check the cams. the door rides up and down on these. When closed the door is no the down side of the cam so gravity holds it closed.
The cams are item 10 in the Refrigerator Door parts and item 40 in the Cabinet Door Parts section.
The gasket is item 5 in the Refrigerator Door parts section.
If you click on the picture of any of the above parts a new page will open often with more info, views and a Q&A section.
The following may also be helpful, check out #3
http://www.applianceaid.com/refrigerator-repair-help.php
