Brand:
Model Number:
Main Symptom: Quit working
What happens & when: Does not work
Parts or tests already tried: Replaced box full circuit boards
Brand:
Model Number:
There are some tests that can be done using the attached tech sheet. However, I would recommend starting with the wires at the door hinge. If there is not a broken wire at the door hinge, test 15 can be used to identify what the ice level sensors are seeing. If the test checks good, the next step would be voltage testing at the ice maker when the optics have a clear line of sight and the door switch is taped closed.
Tech Sheet KSF26C4XYY03.pdf (681.2 KB)
