Dryer won’t stay running when start button is released. The gas is also not turning on (getting warm). I have swapped both relays and replaced the heat control board with a new board. In “Factory Test Mode” every thing will beep Execpt the start button. What else can cause this problem?
FIXED - It turns out the new heat board was defective.
