Two weeks ago the water inlet got stuck open and dumped water all over the kitchen floor. Replaced that and it worked fine for a week. It quit mid cycle. It still has some water in the tub. None of the lights work on the front panel touch pad. There is power throughout the control panel, and the fuse has power through it. What would be the next thing to check. Is there a way to test the front panel touch pad to see if that is what’s bad? I’m tired of spending money on parts that don’t fix the problem. ![]()
Perform the troubleshooting as described in the tech sheets.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KUDM01TJBS0 | AppliancePartsPros.com
