Brand:frigidaire
Model Number:GLEF379DQH
Main Symptom:Having trouble wiring the new heating element 316555800 to the existing wiring
Brand:frigidaire
Take it one step at a time. You have 5 wires, two have small connections, those 2 go to the 2 small connections on the new element, it doesn’t matter the order. You have two wires that go to the inner and outer coils, attach those two. That takes care of 4 wires, attach the last wire to the only terminal that is left. Turn it on and test it. If the inner and outer coils are coming on in the wrong order, just reverse the inner and outer wires.
Continuing the discussion from Wiring the frigidaire stove burner 316555800:
my stove has six connectors
Your new element has only 5 connections, send me a picture of your old element, It may have the black jumper wire.
my stove has six connectors. My mistake it has six connectors but only 5 wires. I will try your advise. Thanks for the help.
