Wiring Sheet/Service Manual needed
Wondering if anyone has a wiring sheet for a Kitchenaid dishwasher model KUDS01FKSS0. I have a problem that the thermal fuse keeps blowing.
Many thanks
Hello zcalvin. Here is an attachment of the tech sheet for the model number you provided. Make sure when you change the fuse, you change the wires for the fuse as well. If not, it will continue to blow the fuse. Hope this helps.
AP3178588
Control panel parts replacement parts for WHIRLPOOL KUDS01FKSS0 DISHWASHER | AppliancePartsPros.com
KUDS01FKSS0.pdf (177.1 KB)
Thanks, that was exactly what I was looking for!
Your welcome! Glad we could help!!:slight_smile: :slight_smile: :slight_smile:
