this dish washer works fine for it’s age. The blower was noisy so I took it out to see if I could fix it. The squirrel cage was hitting the bolts behind it. I fixed that and now can’t remember which wire plugs where. Searched maytag site and user’s guide , can’t find a wiring schematic. blower part has motor - 2 wire mounts, relay -3 wire mounts. Have red yellow purple and 2 double white wires.
Your wire schematic should be inside the control panel or attached to the kick plate of your dishwasher.
If not I will try to locate one from the tech site for you.
Nat
thanks, the kick plate was missing when we got it.
Supposed to be inside the control panel. According to the service manual.
Nat
Here is a service manual, I believe your unit’s wiring is 4-9
http://www.servicematters.com/maytag_library/docs/16007823.pdf
Perfect! that technical information was exactly what I was hunting for! Thanks for you time and assistance.
