Rental unit dishwasher not filling w/water. There is a loose white wire coming from the water inlet valve. The pink wire leading from the inlet valve is properly connected I assume the loose white wire is the problem. What does the white wire connect to. A wiring diagram to/from the water inlet valve connetion would be helpful. Thank you.
Here is the wiring diagram you requested
http://manuals.frigidaire.com/prodinfo_pdf/Kinston/154371501.pdf
