Is the wiring diagram you have the same as the attachment?
If yes.
Then one switch gets a Tan and a BlacK.
The other switch gets a White and a White-Violet (may be just another White).
It does not matter which connectors on the switch as long as they are 2 prong switches.
I do not know what you ean by inner and outer door wires. 15819990.pdf (483.5 KB)
[COLOR=“Blue”]OK - so no polarity issues with which of the wires goes on either side of the switch?[/COLOR]
No. You do not have to worry about polarity in an AC circuit.
[COLOR=“Blue”]
There are 2 wires that go from the wiring harness area of the outer door to a connector on the inside side of the door. Not sure what they are for.[/COLOR]
What color are they?
