Brand: Whirlpool
Model Number: ED26MM1LWR1
Main Symptom: defrost time not working
What happens & when: after defrost cycle will not got back to normal operation. Frig works fine if I manually advance defrost cycle.
I have part W10822278 but this old frig (ED26MM1LWR1) does not have a wiring diagram on it. I need the diagram to install the jumper correctly. The S/N is S53815639. I believe the frig is from 1985, That is as good a S/N look up I was able to do.
Can I get a wiring diagram?
Thanks, Brad.
