MY WINDOW UNIT ALL OF SUDDEN STOPPED AND ITS GETTING POWER BUT THE ONLY BUTTON ON THE DIGITAL FRONT THAT WILL WORK IS THE TIMER BUT IT WILL NOT COME ON
Sorry, can’t help much with this problem other than main control replacement which is probably not available… It may be time to replace the air conditioning unit altogether unless other controls could somehow be substituted… Not recommended here - good luck cheers
