Window A/C compressor won't turn off
After 4 years of use, the compressor runs constantly for this window A/C unit. Regardless of the temperature and thermostat (which seems to work) the compressor stays on and cold air continues to blow. When I turn the unit off the compressor continues to hum. I have to unplug the unit to shut it off. When I plug back in and try again, same problem. Two questions:
  1. which part do i need to replace
  2. is it possible to replace it myself
The unit is in a very tight spot and nearly impossible to remove from window entirely - so i’d like to fix if possible rather than replace - assuming i can access and replace the right part without removing entire thing from window.
thank you!!
If you are good with handling electrical work then you should replace the capacitor yourself.
Heat Recovery Ventilator & Systems | Warm Home Ventilation| Ventis
