Will not wash
Quiet Partner II DU1100XTPBB,Will not wash in any mode. control appearce fucntiong correctly. Fills and starts to try to wash but only makes a buzzing noise and then stops. The machine drains fils and drains fine. It did get louder a few washes before it stopped working properly. So the control panel works it fills and drains correctly but only make a noise when in it goes to wash or in any other mode. I have checked the intakes all the way down to the copper assembly for any dabree that might clog the intake but nothing.
I suspect the main wash motor may be faulty. If you remove the lower access panel from below the door, you will be able to see the motor. Where the motor meets the plastic sump housing, do you see any water marks that would indicate it has been leaking?
