Kenmore model 665 16708
turn manual knob to normail wash water will fill and then it stops. will not cycle, will not drain.
Changed out timer, air gap no clog in hose
Help
Help
Remove the bottom panel and check the motor. If there was a slow water leak and motor is rusted, then the pump & motor assembly has to be replaced.
P.S. The model number you posted is incomplete.
[quote=Gene;40541]Remove the bottom panel and check the motor. If there was a slow water leak and motor is rusted, then the pump & motor assembly has to be replaced.
P.S. The model number you posted is incomplete.[/quote]
Gene, when I remove the bottom panel there is some water dripping where the drain hose is when I turn the motor.
I quess its time for a new one.
