Will not drain at the end of the cycle
If the timer is turned to the rinse cycle manualy after the dry cycle is done it will drain and dry.
Pump and spray arm replacement parts for WHIRLPOOL DU890SWKQ0 | AppliancePartsPros.com
Here is the tech sheet and a manual
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%208275136.pdf
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/56e33eb0e839a7fa85256a8e00510938/$FILE/4322430.pdf
Check/clean the drain system
Check/clean the pump
If both the above are OK then it could be the timer.
pump will function if i manualy turn to rinse after the cycle is finished it drains
Yes, but what can happen is that through the cycle it does not drain out all the water so in builds up and after the last drain you see the accumulation.
