There aren’t any bolts to remove the freezer door gasket so I’m not sure how to get it off. Any ideas?
Brand: Whirpool (fridge)
Model: ER8MHKXRS 03
Thanks!
Model: ER8MHKXRS 03
Thanks!
The following may help.
It will probably have screws under the gasket or it will fit into a slot in the door. I think yours is the latter.
The below should help
http://www.applianceaid.com/refrigerator-door-repair.php#gasket
[QUOTE=denman;813097]The following may help.
http://www.applianceaid.com/refrigerator-door-repair.php#gasket[/QUOTE]
Thanks for responding…I figured out that it wasnt the gasket but I needed to shim the door hinge as it was hanging a bit low and rubbing so I went and got a couple 13 cent 3/8 washers and it works great now…
