Whirpool Dishwasher has no power
I am really struggling. My dishwasher quit working a few days ago so I took the door panel off and saw the door switch had went bad. So I went to the local appliance store and just bought the switch itself that went bad. After I replaced it I was able to wash 1 load and it quit again. This time I bought the door switch kit with the new leads and hooked it up and still nothing. Does anyone please have any idea what could be wrong now? I have power coming to the outlet, but that is all I know.
Replacement parts for WHIRLPOOL DU930PWPQ2 | AppliancePartsPros.com
Check the fuse Item 4 in the “Frame and console” section.
This may also help
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208535431.pdf
