Whirlpool WSF26C3EXF01 side by side after dispensing water the dispenser has a fiarly significant drip that eventually stops but fills the well at times
Brand:Whirlpool
Model Number:WSF26C3EXF01
Main Symptom:water dispenser drips after dispensing water
What happens & when:After dispensing water
For Frigidaire WSF26C3EXF01, if the water dispenser drips or leaks after dispensing, these are the most common causes:
1. Water Inlet Valve (WPW10341320) Not Fully Closing (Most Likely)
  • The water inlet valve opens when the dispenser is activated and should shut completely when released.
  • If the valve seat is worn or debris is preventing a full seal, water continues to seep through.
  • Symptoms:
    • Drips from dispenser after use.
    • Dripping continues for several minutes.
    • Ice maker may occasionally overfill as well.
Test: Disconnect power and water pressure. Remove the water line from the dispenser side of the valve. If the valve seeps water when it should be closed, replace the valve.
2. Excessive Water Pressure
  • Normal refrigerator supply pressure is typically 30–100 PSI.
  • Pressures above about 100 PSI can force water past a valve that otherwise appears good.
  • Symptoms:
    • Strong dispenser stream.
    • Water hammer or banging noises.
    • Intermittent dripping from dispenser.
Test: Measure supply pressure with a pressure gauge at a nearby faucet or refrigerator supply line.
3. Air Trapped in Water System
  • Common after filter replacement or water line service.
  • Causes sputtering and dripping from dispenser.
Correction: Dispense 2–3 gallons of water to purge air.
4. Cracked or Damaged Water Line in Door
  • Water may leak inside the freezer door and appear at the dispenser area.
  • Usually causes leakage during dispensing rather than after dispensing.
5. Frozen Water Reservoir or Partial Restriction
  • Less common.
  • A restriction can create abnormal pressure changes and post-dispense dripping.
Diagnostic Tip
If the dispenser leaks continuously even when not used, suspect the water inlet valve first. If it only drips a few drops immediately after dispensing and then stops, check high water pressure or trapped air before replacing parts.
For this model, I’d estimate:
  1. Water inlet valve not sealing – ~70% probability
  2. Excessive water pressure – ~20%
  3. Air in system – ~5%
  4. Other line/dispenser issues – ~5%
If you can tell me whether the dispenser drips a few drops after use or continues dripping constantly, I can narrow it down further.
