Brand: Whirlpool
Model Number: WSR588FIHZ00
Main Symptom: Ice maker not making ice
What happens & when: Does not Produce Ice, suddenly stopped
Error Code (if any): Test Code 44; 2 - Not harvesting Ice
Parts or tests already tried: Two wires at bottom of freezer door cut. Spliced and installed a jumper for each wire. Still not producing ice.
Is there a reset of some sort. I have seen where you can jump T-H but those seem to be for in freezer ice makers and not in the door.
