dishwasher wont drain on its own..checked for clogs but found out if you just let it run it skips the drain cylce..if you turn the knob manually with your hand through all the cycles it will drain when it hits that cycle. is the timer out?
Sounds like the timer is the culprit.
- The timer AP6012983
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL DU840SWLQ0 | AppliancePartsPros.com
thought so too…cheapest i found is 114.00 ouch!
