Brand: whirlpool Model Number: wee750h0hz4 Main Symptom: won’t heat past 350 What happens & when: while preheating to 375 I heard a hissing noise and a small amount of smoke came from inside the oven. No food or other items were in oven. Now oven will only heat to 350 and it is slow getting to that temperature
The hissing noise and smoke you noticed during preheating are concerning, especially since your Whirlpool WEE750H0HZ4 now heats slowly and struggles to get past 350°F.
My first suspicion is a failed bake element or a damaged wire connection to the element. When an electric heating element shorts or burns through, it can make a hissing or sizzling sound and produce a small amount of smoke.
Your oven uses both the bake and broil elements during preheating, so if one stops working, the oven may still heat but take much longer to reach the selected temperature.
Here’s what I recommend checking:
1. Inspect the bake element first.
Turn off the breaker and allow the oven to cool completely.
This model has a hidden bake element beneath the oven floor.
Inspect the area for signs of burning, discoloration, or damage.
If you can access the element connections, look for melted terminals or burned wiring.
2. Test the bake element with a multimeter.
With the breaker OFF and the element wires disconnected:
Measure resistance across the bake element terminals.
A typical good element measures approximately 15–40 ohms, depending on its wattage.
An OL or infinite reading indicates an open element.
Check from each element terminal to the metal sheath. Both should read OL. Any continuity to the sheath indicates a grounded element.
3. Check the broil element.
Inspect the upper element for blistering, cracks, or burned spots. You can also test its resistance with the power disconnected.
4. Check for damaged wiring.
Since you heard hissing and saw smoke, I would pay particular attention to the element terminals and wiring connections. A loose connection can overheat, arc, and eventually prevent the element from working.
What I suspect
Based on the sudden noise, smoke, and reduced heating performance, I’m leaning toward an electrical failure involving one of the heating elements or its wiring rather than a temperature sensor or control board.
I would avoid operating the oven until the source of the smoke has been identified. An arcing connection could present a fire hazard.
One question:
When you heard the hissing noise and noticed the smoke, did the smoke appear to come from the bottom of the oven, near the back, or from the upper broil element?
That will help us narrow down which component to inspect first before ordering any parts.
When hissing sound was heard my wife looked at the oven door and saw a flash in the upper right corner through the oven glass and then she opened the oven door to check for source. A small amount of smoke curled out the top right of the oven opening.
Sounds like the broil element went look at both elements and see if you see any irrugular spots on the coated part. It should be uniformly smooth all the way to the connection point
I will check the surfaces of both elements when oven cools.
when she was baking the potatoes the oven indicated 350 but it didn’t bake the potatoes through as normal. Could the temperature readings be incorrect.
Thanks for the update. The blister on the bake element, along with it breaking apart at that spot, pretty much confirms the element has failed. The good news is that you’ve found the problem. Now we just need to figure out how to get the old element out and the new one installed.
On your Whirlpool WEE750H0HZ4, the wiring for the hidden bake element is accessed from the rear of the range. Unfortunately, there usually isn’t enough slack in the wires to replace the element entirely from inside the oven.
Here are a few suggestions for getting the range out.
1. Turn off the double-pole breaker first. With the element broken, leave the range disconnected from power until the repair is complete.
2. Remove the oven door. This will make the range lighter and give you a better place to grip the oven frame. Avoid pulling on the handle or control panel.
3. Check the bottom front of the range. Remove the storage drawer, if equipped, and look for anything that might be preventing movement. Also check whether the leveling feet are catching on the flooring.
4. Check for countertop interference. Since this is a slide-in range, the countertop may fit tightly against the sides. Look for caulk, trim, or a countertop edge that might be holding the range in place.
5. Try gently rocking the range. With a helper, carefully work it forward a little at a time. If the feet are catching, thin appliance-moving sliders may help. Don’t force it, especially if the countertop is pressing against the range.
6. Watch for the anti-tip bracket. The rear leveling foot normally slides into this bracket. It should release as the range moves straight forward, but it can catch if the range is lifted or tilted.
Once you can pull the range forward far enough, you’ll need to access the rear element connections, disconnect the wires, and finish removing the damaged element. Be careful not to let the wires fall back into the insulation or cabinet.
One important precaution: Since the element broke apart, inspect the wiring terminals for heat damage before installing the replacement. A burned or loose terminal should be repaired rather than reused.
I have one question before you try moving it again.
When you say the range won’t budge, does it feel completely locked in place, or can you move it forward even a fraction of an inch?
That will help determine whether we’re dealing with the leveling feet, anti-tip bracket, or something holding the range against the cabinetry. I wouldn’t want you damaging the countertop or flooring trying to force it out.
