Whirlpool wdt750sahw0 wont start after being upside down for a drain pump replacement
Brand:
Model Number: wdt750sahw0
Main Symptom:
Error Code (if any): no error codes
Parts or tests already tried: replaced seal and drain pump prior to control panel went bad
Will it run the diagnostic test cycle? Here’s the tech sheet if you don’t have it.
TechSheet-W10904613-RevB (1).pdf (4.3 MB)
Hi Shawncurtin - i uploaded a recording of what mine sounds like in the post I opened for similar issue. does your sound the same?
