Whirlpool WDP540HAMB Starts but won’t finish cycle
Brand: whirlpool
Model Number: WDP540HAMB
Main Symptom: won’t complete cycle
What happens & when: Will start cycle and begin filling with water. After 30-60 seconds it stops running and never goes any further.
Error Code (if any): N/A
Parts or tests already tried: Electronic Control Board W11637581 and fill switch
Is it flashing anything after this happens? Does it have any codes in diagnostics mode?
I’m attaching the tech sheet to help with diagnostics mode if you don’t already have it.
tech-sheet-w11532444-revb.pdf (351.6 KB)
The code it shows in diagnostic mode is “E4E3 wash motor”. Is it safe to assume I have to replace this? I’ve already tried clearing blockages and there aren’t any. The only thing I haven’t tried yet is checking the electrical connection at the motor itself. Also, this is in a rental of mine and it takes time coordinating when I can go over there.
Yup, you’ve either got a wash motor W11612326 that isn’t coming on or a control board W11637581 that isn’t sending voltage to it. You can try testing the motor’s resistance value at the motor, should be about 5-15Ω.
https://www.appliancepartspros.com/whirlpool-mp-pmsm-pw-w11612326-ap7193729.html
https://www.appliancepartspros.com/whirlpool-ctrl-y2g-n75-w11637581-ap7205395.html
