Whirlpool washing machine - No Power WFW9200SQ02
Brand: whirpool
Model Number: WFW9200SQ02
Main Symptom: No Power
What happens & when: Nothing ever
Error Code (if any): none due to No power
Parts or tests already tried: tried leaving unplugged for a couple days. Plugged back in still nothing. Need to know where to test continuity to figure out which board is bad. Seems that individual components are not serviceable
Hello, if voltage is good to the washer, the main control would be the next part to look at, if there is proper voltage going into the control but nothing else comes on, that would be the problem. The part number is W10169230, you may be able to find it online. We show it is NLA
