Whirlpool washer tries to spin, then shuts down
Brand: Whirlpool
Model Number: LSQ9200LQ0
Main Symptom: Tries to spin, then shuts down
What happens & when: Keeps making a clicking noise when it tries to spin
Error Code (if any): none
Parts or tests already tried: gearbox, Motor, Brake tube assembly (with new Brakes)
Replaced Motor, transmission, clutch, Brake tube assembly with new brakes & the washer still locks up when starting spin cycle.
It tries to spin then the motor clicks & shuts down to keep from burning up.
After it locks up it will not turn clockwise, but turning it counter clockwise frees it. Then it turns freely like it should but only c.clockwise. If I turn it the other way it locks back up. It is the brake that is doing it.
The brake assembly is new & it did the same thing with the old one.
When I pulled the basket drive assembly (Brake Tube) out, I moved it out 1 inch ,to clear the brake pads & it spins freely both ways with very little play. I am 100% sure its the brakes.
I checked the Bearing tube with a straight edge, it is not bent. I was going to try the Bearings but they feel alright.
Right now it’s completely tore down, ready to do Bearings.
Not sure what to do next, need help.
Since you’ve already replaced the motor, transmission, clutch, and complete basket-drive/brake assembly, and both the old and new brake assemblies behave the same way, I would not replace the bearings yet.
The big clue is this:
  • Pull the basket-drive/brake tube down about an inch so the brake shoes clear → everything turns freely.
  • Put it back into operating position → it locks in the spin direction.
  • Turning it backward releases it again.
That points to the brake not being released far enough when the washer tries to spin, rather than bad bearings.
On this Whirlpool direct-drive design, the clutch and brake-release cam have to push the basket-drive assembly far enough to release the brake shoes before the basket can spin. If that release mechanism isn’t moving far enough, the transmission tries to spin against an applied brake. The motor then overloads, clicks off on its internal protector, and tries again later.
I’d concentrate on the clutch/brake release area before tearing into the bearings. With the transmission out, inspect the clutch carefully and make sure the plastic brake-release cam is installed correctly, isn’t cracked or worn, and actually contacts the basket-drive brake release properly. Also make sure the clutch is fully seated on the transmission and the correct retaining hardware is installed.
A good test while it’s apart is to manually operate the brake-release mechanism and watch the brake shoes. They should pull completely away from the brake drum. If they only move slightly or one shoe hangs up, you’ve found the problem.
Since the basket-drive tube spins freely in both directions as soon as you move it down enough to clear the brakes, I’d leave the bearings alone for now. That test makes a seized bearing much less likely. The next thing I’d verify is why the clutch/brake-release cam isn’t fully releasing those new brakes during spin.
