Whirlpool Washer Model: WTW4855HW3
I’m hoping someone can help me troubleshoot this before I spend more money replacing additional parts.
Original problem:
The washer became stuck in a continuous drain cycle. As soon as it was plugged in, the drain pump would run automatically and would not stop. Because of that symptom, I ordered and installed a new OEM control board (Part #W11607637 / AP7193509).
After installing the new control board:
- The control board was calibrated successfully (multiple times).
- The drain pump no longer runs continuously like it did before.
- The washer will complete the calibration cycle.
- Drain and Spin functions operate normally.
Current problem:
The Normal cycle will not operate correctly.
What happens:
- Sometimes the lid locks and sometimes it doesn’t initially.
- The inlet water valve will start and stop repeatedly every few seconds while making a humming/clicking sound.
- Other times it fills continuously and does not stop.
- The water level rises well beyond where it should, and it never transitions into the wash/agitate cycle.
- If I manually stop the cycle, the water supply shuts off immediately.
- I can then use Drain & Spin to empty the tub without any issues.
Things already checked:
- Pressure hose was inspected.
- The damaged end of the pressure hose was trimmed and reinstalled.
- The hose appears securely attached and doesn’t come loose when pressure is applied.
- Multiple calibrations have been performed.
- Water supply is normal.
- New control board is a genuine OEM part from AppliancePartsPros.
At this point, I’m wondering if I’m dealing with:
- a pressure sensing issue,
- a faulty pressure hose or pressure port,
- a wiring issue,
- an inlet valve problem,
- or if the replacement control board itself could be defective.
What would be the next thing you would test before I start replacing more parts? If it requires a new part, what would you suggest?
Any guidance would be greatly appreciated.
