Whirlpool washer making a squeak sound when in spin mode
Brand:whirlpool
Model Number: WTW8900BC0
Main Symptom: squeaky / loud
What happens & when: in spin mode it squeaks on and off and seems to be allot louder than normal
Error Code (if any): none
Parts or tests already tried: washer basket hub kit
Photos /video link:
That is probably the tub bearing that is starting to squeal, you can replace the entire tub with the bearing installed, or you can replace the bearing and reuse your old tub. W10435302 Washer Bearing And Tub Seal Kit | Genuine Whirlpool OEM In Stock, and the tools to install it. W10447783 Washer Bearing Installation Tool | Genuine Whirlpool OEM In Stock, there is also a video on how to do it.
