Ever since I can remember there has been a bad taste to the water coming out. I know there are two steps, first replace the water valve/line and then replace the reservoir if problem persists.
I am assuming that I need to replace this first?
Whirlpool 2255153 Water Tube - AppliancePartsPros.com
Please indicate which part I should replace first and then if problem persists the other part(s). Thanks in advance.
