Whirlpool Side by Side door not sitting flush at the bottom
I will try and post a picture of my problem, but ill explain it first. I have leveled my fridge and aligned my doors. The problem is when you look down the side of the refrigerator door, it sticks out about 3/8" more than the rest of the door. The top is flush. What I do see if your looking directly at the fridge is there is more of a gap at the bottom than the top between the doors. So I know the most common problem with these doors are the cams and they wear quickly because they are made of plastic. So I took the door off and examined the top and bottom cam and I do see some but minimal wear. The top and bottom hinge seem to be ok but I am not 100% on how precise they need to be. I have tapped on the bottom and top hinge to see if I could get a change and I did not succeed. The seal is very consistent all the way around the fridge and I don’t see any swelling that could cause this. My conclusion is the door is warped but I am not sure at all. It could be the cams or it could be the hinges I am at a loss because nothing is showing its ugly head.
I do have pictures of the problem but I can’t seem to get the right format to post the pictures.
Host the picture on another site, like photobucket, then post that link here.
