Brand:whirlpool Model Number:WRS325SDHZ05 Main Symptom: filter casing not working What happens & when: whirlpool water filters will not stay locked into filter housing, have tried several new and no change. I have removed the filter casing and found a hole in one of the lines . Should this be there? The other water line did not have a small hole. I only purchase OEM whirlpool filters. Refrigerator is only 6 years old this December? Can a tech please review my post?
Photos / video link: found hole in one of the lines
Make sure you are using an OEM water filter EDR1RXD1 purchased from a reputable distributor, some of the filters you can get from places like Amazon may be a knockoff that is super close to the original but off just enough that they don’t quite work right.
If the filters are OEM then you’d be looking at replacing the filter housing W11162042. As for that water line, it will need to be replaced. I can’t tell from the picture which one that is, but the 2 water lines to the filter housing are inlet line W11162040 and outlet line W11162036.
The line is the large line that was held by the red key. Why does it need replaced please? I have ordered the filter housing already, it should be here tomorrow
The line I pictured is the larger around line and it was the line on top of the housing the other line is smaller and was connected with a blue clip
If I need the line replaced is that what is causing the issue with the filters not staying locked in the housing ?
They should go in a lot easier than they come out, those little push lock fittings tend to get really stiff after a while and make disconnecting lines a pain, but putting the line back in usually isn’t a problem.
