Whirlpool Refrigerator Ice Maker Leaking and some out of dispenser
Brand: Brand:Whirlpool
Model Number:WRF767SDHZ04
Main Symptom: leaking when it fills the ice maker. Have replaced the ice maker, and both valves and it’s still leaking. It’s the main ice maker in the fresh food. Also is dripping some water out the water dispenser also. I’m noticing this when it fills the ice maker with water .
This could be caused by a water filter affecting pressure, the water supply pressure being too high or too low, or it may be a compound issue with partial diode failure. About how old is the water filter, and does the water dispenser seem like it dispenses slower than it used to? If the water supply valve is slightly turned off, does it improve the leak or does the leak stay the same?
