Brand:Whirlpool
Model Number:WFE710H0AE 0
Main Symptom:Top Burners Always on High
What happens & when:When I turn on the Burners
Error Code (if any):None
Parts or tests already tried:Our Left Front Burner started to always run on High so I saw a Youtube Video with the same problem and they replaced a Whirlpool Dual Element Control Switch OEM Part # WPW10434452 so i ordered and replaced the Element Control with that part. Now My Left Rear and Right Front Burners are always running on High. It either Off or High. Did I use the correct part# ?What Parts do I need? TIA !
That would be the correct infinite switch for the Left Front burner, the only thing I could think of that might do something like this is a miswire at the switch.
Could you send a picture of how the switch is wired?
Is the Right Rear burner working properly?
Is the Left Front working properly?
Thanks for the reply…No pictures but the switch can only be wired one way because the wiring harness fits each side differently. Right rear burners seams to work OK.
The Left front and rear burners and the right front burner only go on High and Off. If I remember the two front burners do go on high for both burner elements. IE: The switches turn on the inner and outher rings according to the knob placement.
Were any of the wires ever disconnected from any of the elements themselves?
As long as the harness was never disconnected from the elements themselves and only that switch was replaced, there should be no way that the LF switch is causing the issue. What makes this odder is that the left and right side burners and switches are on separate harnesses, left-side on harness W10349716 and right-side on harness W11134550. Further, the right rear is working, so it shouldn’t be a source electrical or main harness issue, if it was doing the same thing as the others that’s what I would suspect.
Thanks Again…Here is the video I watched with the part # I ordered to replace the Elements switcha for the Left Front Burner
