Whirlpool Quiet Partner III
Hello - I have a Whirlpool Quiet Partner III model number GU2455. The pots and pans light and the normal wash lights are flashing. It won’t start. I have unplugged it and tried to press normal again then the pots and pans light starts flashing again and the normal kicks in in a minute or so. Any suggestions? Thanks!
Sounds like either a control panel (keypad) or a control board problem.
Your model number is missing several digits at the end so I cannot find the correct tech sheet/wiring diagram.
The normal way to trouble shoot this is to check the keypad with a meter.
If it checks out OK then replace the control board.
Still a bit of a crap shoot but your odds are better.
You could try the following but it would be a long shot as it usually repairs open keys/connections and flashing is often due to always closed keys.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
