Recently we have noticed that dished especially in the top rack are not getting clean, even after they have been rinsed prior to loading.
I open the dishwasher when it is running and it appears to be circulationg water.
What should I be checking to verify the water pressure is adequate to clean the dishes.
What steps should I take to figure out what is wrong with this dishwasher?
Is this a common issue withthe Whirlppol.
Gene
March 7, 2009, 4:33am
2
Check the chopper as described in one of our previous posts: http://forum.appliancepartspros.com/dishwasher-repair/2903-whirlpool-dishwasher.html
Here are the break down diagrams and the parts list for the Whirlpool dishwasher Model GU1200XTLB3
Hello Geneā¦
I was hoping you could help. My Whirlpool Dishwasher GU1200XTLB3 is NOT draining the water..what could it be? What part could it be??
Thank you,
Ms. D
Gene
August 5, 2009, 12:24am
4
Ms. D,
The first thing I would do is check the air gap on top of the sink (if there is one) for a clog.
If there is no air gap then remove the drain hose from the garbage disposer, put the end of the drain hose in a bucket and run the drain cycle. Watch how it drains and post the results.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GU1200XTLB3 | AppliancePartsPros.com
