my quiet partner iii dishwasher does not heat water for the wash cycle, what systems should I check to fix this. i did not see a thermostat or min heat sensor on the part number.
Here is the parts breakdown
Replacement parts for WHIRLPOOL GU2400XTPS7 Undercounter Dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208572216.pdf
Try the diagnostics.
Then, I would check the heating element and the hi-limit thermostat with a meter for resistance, see the tech sheet.
If OK
Check the wires going up to the control board.
If OK
Check the thermistor for resistance.
is that the same as the vent? pardon my ignorance, but UIdont see a thermistor in the parts diagram. ![]()
[quote=denman;212314]Here is the parts breakdown
If OK
If OK
Check the thermistor for resistance.[/quote]
No it is different.
Right hand side bottom of the diagram (blue boxes)
