Dishes won’t dry. All the glasses are wet. Help!
Here your parts
Replacement parts for WHIRLPOOL GU1200XTLQ3 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208537797.pdf
I would check the heater and hi-limit thermostat but I would have thought that you would have also noticed long cycle times since it did not heat up the water.
I would also check the vent wax motor if your unit has one, could be it is not opening. If you open the unit during a dry cycle and it is very hot but still the dishes end up being wet, then this would be at the top of my list.
