Whirlpool Quiet Partner II not responding
So I woke up this morning to run the dishwasher before family starts to arrive for Christmas and the d/w doesn’t respond. There are no lights coming on anywhere on the control panel. I just used it less than a week ago and it worked fine?
I flipped the circuit breaker switch off and back on but that did not do anything either. Any suggestions???
Replacement parts for WHIRLPOOL DU1100XTPS7 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
It is best to check power with a meter.
Many units are connected to power with wire nuts.
Shut the breaker off and check that these connections are OK.
Check the thermal fuse Item 6 in Section 2.
If blown be sure to use the new harness that comes with the replacement,
