du148xtpba dishwasher ,cancel drain will work start button will not , when I press high temp wash then heat dry , high temp wash heat dry all leds light and it runs for a few minutes at best then shuts off . no blinking lights or nothing pushing start button nothing either , any clues ?
Mark,
I believe your model number is incorrect, is it DU1148xtpba ?
That’s the closest I can get to the number you supplied.
You most likely have a bad keypad / control panel assembly,
I’m attaching a copy of the diagnostic,service test.
When you program in the diagnostic cycle, if the control does not accept it,
Replace the Control Panel / Key Pad Assembly
(the manufacturer never came up with a touchpad matrix test).
If it does accept the program, let it run the complete test cycle, so you reset the main control board memory(in the panel), provided there are no lights on at the end of the test.
If there are light(s)on, or the test mode stops during the test , you may have to replace the control board.
Good Luck,
SERVICE DIAGNOSTICS CYCLE NOTES[FONT=Swiss721BT-BlackCondensed][SIZE=1]
NOTE 1.
[/SIZE][/FONT]To invoke the Diagnostics Cycle, perform
[SIZE=1][FONT=Swiss721BT-RomanCondensed][LEFT]the following key presses or actions in less than
[LEFT]6 seconds while in standby:
Heated Dry [/LEFT]
[/FONT][/SIZE]
[/LEFT]
[LEFT][/FONT][/SIZE]➙ Normal ➙ Heated Dry ➙ Normal
[/LEFT]
[FONT=AdobePiStd][SIZE=1]
[/SIZE][/FONT]To rapid advance one interval at a time, press the
[SIZE=1][FONT=Swiss721BT-RomanCondensed][LEFT]Start/Resume key.
[/FONT][/SIZE]■ [FONT=AdobePiStd][SIZE=1]
[/SIZE][/FONT]
[/LEFT]
[/SIZE][/FONT]Invoking Service Diagnostics clears all status and
[SIZE=1][FONT=Swiss721BT-RomanCondensed][LEFT]last ran information from memory and restores
[LEFT]defaults; It also forces the next cycle to be a sensor
calibration cycle.
Calibration cycles begin with a “sensor check” to
determine whether the dishwasher has an OWI soil
sensor or not. If the control detects an OWI, it forces
two rinses to occur prior to Final Rinse (to assure
clear water), then calibrates the OWI during the final
rinse.
[/FONT][/SIZE]NOTE 2. [/LEFT]
[/LEFT]
[/SIZE][/FONT]Turn on all LEDs immediately upon
[SIZE=1][FONT=Swiss721BT-RomanCondensed][LEFT]receiving entry sequence (even if door open) and
[LEFT]throughout this first interval as a display test.
[/FONT][/SIZE]NOTE 3. [/LEFT]
[/LEFT]
[/SIZE][/FONT]On numeric time display models, display
[SIZE=1][FONT=Swiss721BT-RomanCondensed][LEFT]the following software information after the initial
[LEFT]display test:
[/FONT][/SIZE]■ [/LEFT]
[/LEFT]
[/SIZE][/FONT]Interval 18 – Dishwasher control platform number
[SIZE=1][FONT=Swiss721BT-RomanCondensed][LEFT](“d3” Raptor/Tall Tub, “d2” Cheetah/Briva, “d1”
[LEFT]Rush/Tall Tub, “d0” New Gen).
[/LEFT]
[/SIZE][/FONT]Interval 17, 16, 15 – Software generation number
[SIZE=1][FONT=Swiss721BT-RomanCondensed][LEFT](incremented for each release of software to
production).
NOTE 4. [SIZE=1][FONT=Swiss721BT-RomanCondensed][FONT=Swiss721BT-BlackCondensed][SIZE=1]
[/SIZE][/FONT][/FONT][/SIZE][/FONT][/SIZE]
[/LEFT]
[SIZE=1][FONT=Swiss721BT-RomanCondensed][SIZE=1][FONT=Swiss721BT-RomanCondensed][FONT=Swiss721BT-BlackCondensed][SIZE=1]
[/SIZE][/FONT]If flow meter is operating correctly the
[SIZE=1][FONT=Swiss721BT-RomanCondensed][LEFT]control will turn on the Clean LED when flow meter
[LEFT]counts 3 or more pulses anytime during these
intervals.
[/FONT][/SIZE]NOTE 5. [/LEFT]
[/LEFT]
[LEFT][/SIZE][/FONT]Thermistor (temperature sensor) checks:
[/LEFT]
[/SIZE][/FONT]Turn Clean LED on if thermistor is in its normal
[SIZE=1][FONT=Swiss721BT-RomanCondensed][LEFT]temperature range of 17°C–71°C (62°F–160°F).
[/SIZE][/FONT]
[/LEFT]
[/SIZE][/FONT]Turn sanitized LED on if thermistor is above
[SIZE=1][FONT=Swiss721BT-RomanCondensed][LEFT]38°C (100°F).
[/FONT][/SIZE]NOTE 6. [FONT=Swiss721BT-BlackCondensed][SIZE=1]
[/SIZE][/FONT]
[/LEFT]
[LEFT][/SIZE][/FONT]OWI (optical soil sensor) checks:
[/LEFT]
[/SIZE][/FONT]Check OWI sensor for the presence of clear water
[SIZE=1][FONT=Swiss721BT-RomanCondensed][LEFT]during the 5 sec. pause in interval 13 and turn on the
[LEFT]Clean LED in interval 12 if clear water detected.
[/LEFT]
[/SIZE][/FONT]Check OWI sensor for the presence of air during the
[SIZE=1][FONT=Swiss721BT-RomanCondensed][LEFT]last 5 sec. of Drain interval 3 and turn on the Clean LED
[LEFT]in interval 2 if air detected.
[/LEFT]
[/SIZE][/FONT]Check OWI sensor for presence of bulk soil in the
[SIZE=1][FONT=Swiss721BT-RomanCondensed][LEFT]water during pause interval 8; execute max. allowed
[LEFT]APFs and turn on Clean LED in interval 7 if bulk soil
detected.
[/FONT][/SIZE]NOTE 7. [/LEFT]
[/LEFT]
[/SIZE][/FONT]Heater relay must lag wash motor relay by
[SIZE=1][FONT=Swiss721BT-RomanCondensed][LEFT]1.5 sec. at start-up of heated wash intervals to avoid
simultaneous heater and motor in-rush current
[/FONT][/SIZE]
[/LEFT]
model was wrong you are corect I forgot to tell you I have replaced the electronic control and ran the dionostic test it ran this time for about fifteen min I think it stoped short though because the clean LED never lit up , I unpluged the ribbon and turned power back on and the motor ran for two min per tech sheet BUT the start button wont start the machine thanks for your help let me know if you have any more sugestions.
Mark,
We’re back to the Key pad / Control panel assembly.
Try this first, disconnect the ribbon from the electronic control board, clean the end of the ribbon with rubbing alcohol, and re-insert it into the connector, tightly.
If you still can’t program or start the machine, replace the part.
Did you ever have a blinking light above one of the selection key pads?
Yes I notice NOW if ipush any of the selection keys the led will light up three times , I too think now it is the touch pad or the conection when I get home I will try to clean it I will let you know what happens THANKS!!!
OK,
Will be looking for an update from you.
Thanks,
Medium The Complete Season 1-5 DVD Box Set
- Price:$34.99Purchasing Medium The Complete Season 1-5 DVD Box Set requires only $34.99, which is 40%-60% of the price on ******** even plus the postage, in addition, we will present three most popular DVD movies. It will be a not bad choice for you to enjoy them by yourself, present them to your friends, sell them out or dropship(dropshipping) them to your clients.
Hi Joe, I have a Wirlpool DU1145XTPQ7 that doesn’t want to start. When I select Normal the Heated Dry lamp come on automatically, and seem to flicker on and off like it has a short or something for about 2 to 3 mins, and the Start button doesn’t work when I try to start the cycle. Can you help?
Thanks, Young
[quote=yblim;793396]Hi Joe, I have a Wirlpool DU1145XTPQ7 that doesn’t want to start. When I select Normal the Heated Dry lamp come on automatically, and seem to flicker on and off like it has a short or something for about 2 to 3 mins, and the Start button doesn’t work when I try to start the cycle. Can you help?
Thanks, Young[/quote]
Young, Like the previous post, you most likely have an issue in the keypad assembly.
You can remove the lower kickplate panel and you should find the “Tech Data Sheet” attached to the back of the panel. You can then test each keypad circuit, with a multimeter, and program into the diagnostics tests, etc. and verify the issue and the proper operation of the dishwasher, and yopu’ll be up and running in no time.
