Whirlpool Qt Prtnr II, Replaced Htg Element Does the Control Panel Nd 2 B Replaced?
[FONT=Arial][SIZE=3][COLOR=#000000]The heating element suddenly broke in two for no apparent reason. We’ve had it since Oct 2005. I’ve purchased a new heating element however now I’ve been told that the control board needs to be replaced whenever the heating element is replaced. Is this true? Is this really a necessity any time the heating elements are replaced?[/COLOR][/SIZE][/FONT]
[FONT=Arial][SIZE=3][COLOR=#000000] [/COLOR][/SIZE][/FONT]
[FONT=Arial][SIZE=3][COLOR=#000000]If yes, what is the correct part number for the control board/panel/electronic control board?[/COLOR][/SIZE][/FONT]
[FONT=Arial][SIZE=3][COLOR=#000000]And can I just replace the interior electronic control board without replacing the entire Control Panel that is on the outside at the top of the dishwasher?[/COLOR][/SIZE][/FONT]
[FONT=Arial][SIZE=3][COLOR=#000000]Please hurry with any correct info as the dishes are piling up. [/COLOR][/SIZE][/FONT]
[FONT=Arial][SIZE=3][COLOR=#000000]Thx,[/COLOR][/SIZE][/FONT]
[FONT=Arial][SIZE=3][COLOR=#000000]DirtyDishes4Five[/COLOR][/SIZE][/FONT]
Replacement parts for WHIRLPOOL DU1145XTPB3 Undercounter Dishwasher | AppliancePartsPros.com
Who told you this?
I do not see a heater and board kit listed in your parts so I am assuming it does not need a board. Also the kit is only for stainless steel tubs.
It comes as a kit. Below is an example this is for a Kitchenaide KUDI01TJBL1.
AP3841139
You could call AppliancePartsPros to confirm the above.
Yes if it needed one it would be just the control board.
