Remove the upper dish rack.
Remove the water feeding tube for the upper spray arm.
Remove 4 screws (#3 on the break down diagram) holding the top cover (#1).
Remove the inlet protector (#8) holding by the tab on the right side.
Check the chopper (#6) for any clog.
Check for any foreign objects in the pump sump.
Clean all debris and assemble in the reverse order.
If it would not help, then the problem most likely is a bad motor.
I have the same problem, and cleaning out the sump etc did not help. Would you recommend replacing just the motor (AP4434021), or the entire motor/pump/sump assembly (AP4434612)?
On a related note, sump housing AP3866228 has a 32.17mm hole for the thermistor and says if my thermistor is 31-31.5mm I should order sump housing AP3775547 instead. 0.67mm is a very, very small difference; I don’t think I could measure it that accurately. But then in the complete sump and motor assembly AP4434612, it says that sump has “the larger 23.96mm hole for the thermistor” - described as being larger, but it is smaller than the hole size listed in both of the sumps sold separately. There’s only one thermistor listed, with no size given. Now I really don’t know what to order. Please help!
My apologies, I didn’t realize there were multiple models of “Quiet Partner I”. Mine is model DU1055XTSQ3, serial FW1206371.
It makes a loud sort of howling noise during the wash cycles, much louder than when it was new a few years ago, and louder than even a month or two ago. I cleaned out some debris from the chopper area, but the noise did not change; I disassembled it again just to make sure, and there was nothing else in there.
I would suggest the whole new pump & motor assembly replacement as more reliable repair than just the new motor, but there is $40 difference for parts.
Thank you. Replacing the bearing for $1.77 is tempting, but it’s such a pain in the (neck) to uninstall/reinstall in my particular installation, rather than risk having to pull it out yet again to replace the motor if the bearing fix doesn’t work, I think I’ll just sink the $150 and replace the entire assembly, once and done. I’ll place my order shortly. Thanks again.
I replaced the complete pump / sump assembly. Really the only hard part was getting the sump seated in the bottom of the tub; I laid the machine over on its side and from inside the tub, pressed the whole sump assembly firmly into the hole, and my wife installed the three wedge / clip / retainer things from the other side.
I disassembled the old motor: the bearing on the impeller / volute end was almost completely frozen.
It is now MUCH quieter; the noise of the water splashing around inside is actually louder than the motor.
