Whirlpool oven taking long to reach temp
**Brand:**Whirlpool
Model Number: GR563LXSS
Main Symptom: Long hear time
Preheat beeps but temp is still not up. Will eventually heat up . I have replaced sensor and
Not sure why it cut half of what I typed. Set preheat to 350, oven beeps, temp is only 200, wait another 20 to 30 min then hits 350. I have replaced temp sensor and bottom heating element. Please help. TY
I found GR563LXSS0, GR563LXSS1, GR563LXSS2
Some model# helps…
Bake element gets red?
Oven temp sensor ohms at 1000-1100 ohms at room temp?
Oven door closes ok?
If the element works correctly, if the oven temp sensor checks ok…leaves the clock/control as the prime suspect.
jeff sr.
