its a side by side freezer/fridge
so both the fridge wasn’t cooling down and the freezer items started to defrost.
there was a lot of ice visible on the freezer inside panel. so i checked the following:
- thermostat..it was closed (showed continuity) when it was frozen and it showed open (no continuity) when at room temperature. means = thermostat is good
- checked heater wire: shows a resistance of 23.7 ohms…i think this is good, right?
then i removed the thermostat, and joined the wires together to bypass the thermostat to ensure the loop is closed, then:
3) voltage at the wires for the heater measure = 6.7volts
4) i had a spare defrost control board, put it in there and measured the voltage at the wires, replaced it and the voltage still measure 6.7 volts at the heater wire.
question:
- what voltage should i be reading at the wires at the heater…120v AC, right?
- by connecting the wires for the thermostat, i have closed the loop right? so the board should be sending voltage for the heater wire to turn on, right?
- what is wrong?
- how do i know if the defrost control board is bad? at the white and black terminals on the the defrost control board, it measures 120 volt
