Whirlpool leaky door
I have a leak at the bottom of my door. It only happens when the dishwasher starts to cycle. It will fill complete. There is nothing stuck and I have cleaned the bottom. The sound barrier is rigid along the bottom, Is this normal ?
Sometimes the lower spray arm will start spraying directly at the seal instead of up to the dishes. This can be caused by a crack or hole in the arm or something stuck in one of the holes that redirects the spray.
Can a couple of the screens in the filter that have lifted from the edge cause enough pressure to cause a leak between the door dishwasher cabinet ? Does the filter system have little marbles in it ?
