Whirlpool LE7800XSW3 no heat, drum spins
Brand: Whirlpool
Model Number: LE7800XSW3
Main Symptom: No heat
What happens & when: Drum spins
Tested Thermal Fuse - continuity
Tested Heating Element - continuity
Tested Thermal Cutoffs, bottom - continuity, top - no continuity
Ordered new Thermal Cutoffs.
Do I need to check Cycling Thermostat?
Had problem approximately 1 year ago with Thermal Cutoffs & Cycling Thermostat; replaced both.
Does not appear to be any blockage in exhaust.
The cycling thermostat would most likely not be the cause for this. If the thermal cut-off has failed then this would be the issue and would need to be replaced.
