Whirlpool (kenmore) range electric oven - no heat
Brand:whirlpool
Model Number:79075503202
Main Symptom: no heat, main oven
What happens & when:20-Feb-2026
Error Code (if any): none
Parts or tests already tried:checked all 5 possible causes of no heat as posed in a.p.pros.com video
  1. voltage 120± for each leg and 240± across both power legs
  2. bake element ohm: 18
  3. thermal fuse continuity: good
  4. temperature probe ohm: 1080 good? Where can I find the table for this make/model/part?
  5. broil element ohm: 20
Where you would want to start is testing for 240 vac on the bake and broil element. If there is not proper power then this will be a faulty control board.
